It is currently Mon Aug 18, 2025 3:14 am
 Post subject: Binding glue voids
PostPosted: Wed May 07, 2014 10:39 am
Last Name: Lloyd
City: Denison
Zip/Postal Code: 75020
Does anyone know if the alcohol used in french polishing can dissolve the yellow glue used to glue bindings?
 Post subject: Re: Binding glue voids
PostPosted: Wed May 07, 2014 12:19 pm
First name: Gil
Last Name: Draper
City: Knoxville
State: Tennessee
Hi Dennis,
Consider doing an experiment. Good luck.
PostPosted: Wed May 07, 2014 12:27 pm
Last Name: Ulman
City: Bellevue
State: Washington
I use 190 proof ethanol for FP and never had a problem with it dissolving Titebond original, LMI white or HHG. Not sure about the various mixes of denatured alcohol out there. Can you describe what you mean by glue voids?
Joe
Edit: I guess I should have clarified that I never had an instance where the alcohol dissolved cured glue on the instrument. After reading Joe Beaver's response I think I understand the problem.
PostPosted: Wed May 07, 2014 3:13 pm
Last Name: Beaver
City: Lake Forest
If you are trying to remove the glue in voids I would say French polish alcohol is not going to do it for you. That's assuming the yellow glue is cured.
Joe Beaver
Maker of Sawdust
PostPosted: Wed May 07, 2014 6:47 pm
vinegar will soften yellow glue. Use stainless steel or plastic implements if you need to pry things apart. Regular steel will leave a black stain when it comes in contact with vinegar.
